BFL13
Sep 01, 2021Explorer II
wnjj wrote:BFL13 wrote:
In the link for the Link it shows the yellow wires going to each gen's chassis ground lug.
How does the chassis ground for the gen connect to the gen's receptacles' neutrals by using the bonding plug unless the gen's chassis is connected to the receptacles' grounds?
Is that what wnjj meant above?
Yes, the ground pins on the 20A receptacle are connected internally to the ground lug, which is where you attach the parallel kit ground.
See my edit from the B&S manual above though.
