Fisherguy's avatar
Fisherguy
Are the new WFCO's as bad as the old ones?
Our old trailer (2007 Komfort) had a WFCO 8955 converter in it, I could NOT ever get it to go into bulk mode, not even when I moved it within a few feet of the batteries, tried everything. I did a thread on it. (I ended up putting a PD9280 in a new location closer to the batteries.) Any converter thread got pretty heated back then as I'm sure some of you will remember! ;)
We just bought a 2019 ORV Timber Ridge which unfortunately also came with an WFCO, this time a 8955 Lis. This is the one with a lead/lithium switch.
This trailer came with 3 - 100Ah LIthiums, has 600 watts of solar panels uptop and has a 12v Norcold fridge. (I might add another 200 watt panel and additional 100Ah Lithium if I need to?)
So are these new WFCO still as bad as the old ones?
If they're better I could replace the charger with a 8975 if it fits? (I'd have to upgrade the cables to the batteries I know)
Either way I'll be wanting to upgrade the charger for one as big as possible that will run from my Honda 2000 genny.
I'm hoping to shorten the learning curve re. lithium charging, this is all new to me.
Thx
Will
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
