corgidad's avatar
corgidad
Atwood check valve
Looking for any advice on replacing my hot water heater check valve as it has started to make a buzzing noise like there is trash in it or it is coming apart inside. It attaches directly to the back of the HWH and a plastic T connector. It look like if I try and remove the CV the other end will tighten on the plastic connector. Looks like I will have to remove and disassemble the Bypass valve and all the lines to replace it. If anyone has replaced theirs any tips would be greatly appreciated. Thanks..
  • Should be a screw on connection for Hot water line to HWH outlet.....then other connections/fittings would be crimped/clamped on
    Same for cold water inlet.........should be a screw connection
    Check valve IS internal assembly of that nipple screwed into HWH Tank Hot out.
    IF no screw connections then you will have to cut crimp band off-----and cuss RV MFG. for doing it that way
    Here is how it should be..screw connections at tank
    The wrong way...ALL crimped connections
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
