GaryS1953
Feb 02, 2019Explorer
BFL13 wrote:
You have an 8531-111 or some such? Ok you obviously have a short in the 12v somewhere. It showed up after the motor ran the fan but then it happened. The sequence for ignition goes through a number of things so need to pin down where it stopped.
You said there was gas but no ignition, and then it shorted again? Please confirm you smelt gas. If you did that means the 12v got that far, but if you didn't really smell gas then the fault could be earlier in the sequence.
no, smelled electrical smell. Never smelled gas.
