goofasap
Feb 18, 2014Explorer
atwood hot water heater thermal cut off connections
I have a atwood model gc10a4e hot water heater. The thermal cut off wire connection corroded completely off at the end which connects to the water heater.
One of the two male tabs is completely broken off. Will this require an entire water heater replacement or does the component the wire connector plugs onto screw out and is replaceable? I have not found any schematic that clarifies this.
