Apr-24-2020 09:25 AM
Apr-27-2020 07:10 AM
Apr-27-2020 04:49 AM
dougrainer wrote:mchero wrote:
Whats the model of the OP's water heater?
GOOD question. To the OP---- If your model has XT in the model number, then ALL the previous posts are null and void. XT stands for a Mixing Valve Atwood. There is no reason to install a Adjustable Tstat. Also, the Standard Atwood Tstat will NOT fit a XT model and the XT model tstat will not fit the standard Atwood. Doug
Apr-26-2020 08:54 PM
Apr-26-2020 05:16 PM
Apr-26-2020 04:31 PM
Apr-26-2020 08:21 AM
happy2rv wrote:dougrainer wrote:
1. I always wonder where people think there is a "code" or "Legal Limit" for things. THERE IS NO LEGAL TEMP LIMIT FOR WATER HEATERS. There is a 125 psi PRESSURE limit in most codes for water heaters.
2. The REASON for 130/140 Auto set Tstats on 12 volt DSI RV water heaters is simple. To get the MAXIMUM amount of hot water(mixing cold with hot) they use the 130/140 auto set Tstats.
3. There are RV water heaters that have a 160 degree tstat and that model has a auto-mixing valve on the exit on the back of the water heater that drops the temp to about 120. BUT, it is adjustable and you can fiddle with the adjustment to get hotter or colder output water.
4. Pilot Controlled RV water heaters do have an adjustable Tstat.
5. The BEST solution for the OP is to buy the aftermarket Adjustable Tstat kit. Doug
https://www.amazon.com/Atwood-93105-Adjustable-Electronic-Thermostat/dp/B001BZ36HM
I tend to shy away from absolutes. There are laws in some states and local areas. For instance the state of washington. According to inspectopedia, a number of states have adopted codes with a 120 degree maximum. I believe some locations, especially other countries, have minimum temperature regulations to prevent bacteria and legionnaire's disease.
I know there will be another set of people who want to argue over whether these apply to RVs. Personally, I don't think most of us are really concerned about "regulations".
I'm also hesitant to make blanket statements about what is "BEST" because everyone's situation is different. BEST for you is what works for you and there are many factors that go into deciding what's best. For many, as some have suggested, "BEST" is to do nothing and mix more cold water with the hot. It's certainly the cheapest and requires no physical changes. But there are obvious drawbacks of potential scalding hazard and not being able to keep regulated temperatures. Obviously, I think the OP was aware that was an option and was looking for a "better" solution for his purposes.
An adjustable thermostat is cheaper than a mixing valve and doesn't require plumbing changes, but it does have potential downsides. The two biggest are less hot water and the risk of bacterial growth with lower temperatures.
Mixing valve with anti-scald isn't cheap, but it's cheaper than a new water heater. It does require plumbing though. More work to install. For my purposes, this is a better solution. The OP will obviously have to decide what the "BEST" solution is for his situation.
Apr-26-2020 06:26 AM
Apr-26-2020 06:03 AM
Apr-26-2020 05:16 AM
Apr-26-2020 05:11 AM
Old-Biscuit wrote:Mike134 wrote:Old-Biscuit wrote:
Mike134 wrote:
Maybe you mis-read my post. What you describe is exactly what I had - a shower head with an on/off button. Despite this, when turned back on it was all hot for a few seconds. So it wasn't that I had to readjust the valves - they were already adjusted. I am just thankful it wasn't my son that got burned.
My shower head with the push button does the same thing. Not sure how the water remains circulating but it's just a straight hot water blast till the tempered water mixes in a few seconds later. Must be a design flaw since we both have had that happen
______________________________________________________________________
When you stop/limit flow thru shower head using the on/off button/lever on the handle the shower faucet acts like a mixing chamber.....
Hot water typically is at a higher pressure then the cold water due to pressure increase in WH tank from heating the water (it swells when heated/pressure increases from the swelling)
So when you turn shower head back on...hot water flows first until mixing of hot/cold in faucet catches back up with previous adjustment of knobs.
Simple thermal dynamics .......
Simple 'cure' ---- turn shower head away from you when first turning it back on via shutoff on handle.
Slow learners may require getting hit with that hot water a couple of times but should come to remember to turn head away initially.
I appreciate the explanation about the thermal dynamics makes sense.
To bad the rest of your answer shows you to be an a**h**e
Tisk tisk....not nice to call people names
But if you are one of those slow learners I guess it is the best you can do
Apr-25-2020 09:19 PM
Apr-25-2020 06:24 PM
Apr-25-2020 05:40 PM
Apr-25-2020 04:30 PM
