Gjac
Feb 08, 2019Explorer III
I would start by checking the voltage on the brown wire to see if it has 12 volts. If so remove the thermal fuse and connect the brown wire and connect it to the tstat directly. If it works you know it was the thermal fuse. If it still will not light remove the multi pin plug at the control board and clean connection. If you do those things and let us know what you found you will get it fixed.
