dougrainer
Aug 31, 2017Nomad
The usual cause of pilot light going out when activating the Oven burner is a defective gas tstat valve. THINK of your logic here. The Thermocoupler senses the heat and tells the Oven tstat valve to keep the pilot open and flow the gas. Just turning the oven ON to heat will NOT cause the Thermocoupler to fail. Doug
