Branson_in_Tucs's avatar
Mar 09, 2015
Atwood Water Heater.
Have a small leak in hot water tank. Not sure if its on the tank or a connection hose. Looks like it is coming from underneath. How hard is it to install one your self.
  • Before you go off on dismantling and/or replacing parts.......
    Replace the Drain valve it is plastic they leak all the time.
    If I have to drain my hot water heater I automatically replace that darn plastic plug because it never goes back in with out crushing the threads.
  • Gjac's avatar
    Gjac
    How old is your tank? when mine was 15 years old I thought it was leaking and needed to be replaced. when I looked in the back I noticed 2 plastic nuts as the previous poster mentioned. I put some paper towels under the nuts to determine where the leak was coming from. Several hrs later I went back and the paper was wet. After tightening them again no more leaks. This happened when camping in very cold weather below freezing.
  • Look on the back of the water heater. If it has a plastic, instead of brass backflow valve, they are known to get a small crack and leak.
    The backflow valve will be screwed into the back of the tank, and the water hose screwed on to the backflow valve.
  • Sorry failed to mention its 10 gal electric and gas. I can get to it and disconnect the gas and water connection fairly easy.
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 24, 2025
