StirCrazy
Jun 25, 2023Moderator
Auto Change over bit it
so getting the 5th wheel ready for the first trip of the year I was puzzled as to why the microwave display wasn't on and started to get choked as I just had the microwave fixed last year. then I noticed the lights on the tv's were off and the fridge was running on propane.
after 15 min of trouble shooting with the multi meter I traced the problem to the go power TS-50 and specifically the contactor where they wired the shore power cable to was not engaging, while if I turned the other side on the inverter would make it clunk and supply 120V.
Looking at it I noticed they had the solar going into the contractor, that by their drawing, should have been for the shore power, and the shore power was going into the one labeled for the generator. Are these two contactors the same and you can do this to pick which one gets priority? or is one rated higher than the other?
anyways I switched the shore power to the proper and still working contactor and put the inverter on the dead one since we will have power available this trip so I have 120V power again, but I do have to look for a new change over, so what are your recommendations, should I stay with the go power or is there better ones. go power used to be pretty good quality but who knows whats good now.
