MR_MAC
Dec 09, 2015Explorer
Aux propane tank hook up -- fittings
I want to be able to connect a 20 LB propane tank, with a tee, valve, and fitting to connect a short gas hose to a Motor home tank outlet. Every place I've looked all I can find is kits to run gas from the MH tank.
I stay for two or three Months at a Fla. CG, last year I ran out, and being a pain to move, had a PP truck make a delivery. I got the del and the shaft also. My water htr. runs on gas only, I've thought of installing an ele. heater in the tank, has any one had good luck with doing this. A spare tank or ele element install.
