Puttin's avatar
Puttin
Back up monitor went out
I have a Voyager # VOM-735SNWIN that is no longer working. I want a direct replacement but it's hard to find. If I can't get one will a color monitor work or do I have to change the cameras too? It looks very much like this one but the model # is different.
  • They are priced at what the market will bear - NOT what is costs to produce
    Made in China and might have a total cost of production of $25.00 or less
    Chances of the CRT being defective are VERY low - check out a TV repair shop
    Yes soldering will be needed for proper repairs
  • I'd love to repair it myself but I don't know who has the correct CRT and unless it just plugs in, the soldering might be dicey. I'ts also hard to understand why these things are priced between $300 and $400. Maybe I just haven't searched enough. Thanks for the reply.
  • Those 7" CRT B&W monitors are very easy and simple to repair
    Being a CRT and mono chrome to boot its most likely not worth the repair costs unless you do it yourself
    Yes a color TFT/LCD will work fine with a B&W camera
    No need to change the camera unless you want a color view of what's behind you
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jul 02, 2026
