Old-Biscuit
Sep 17, 2020Explorer III
Is that on the Return side?
YES...then you will end up with diminished return airflow which can lead to Evap Coil Icing up especially with fan speed on low
RV A/C Units are 'recirculating' units...inside air gets sucked in/cooled down/discharged back inside
You source of smoke is via bad slide seals, open roof vents, open windows, entry door leaks etc
It's not from the A/C Unit.
Having RV issues? Connect with others who have been in your shoes.24,198 PostsLatest Activity: Feb 12, 2025
