mrad's avatar
mrad
Jun 16, 2014
Bal X-chocks vs. Deluxe chocks
Do the deluxe chocks give better performance than the x-chocks?
I had a pair of deluxe that are not bent (this is what happens when each family member has a job and two of members are missing when trailer gets hooked up and driver does not do a walk around before pulling out). I can get two x-chocks for $75 vs. one deluxe for $61.
  • Search for a post in Do It Yourself Modifications. There is a post there titled "Homemade Wheel Chocks" that are better than anything available on the market in my opinion.
  • I'm happy with my BAL X-chocks... but I don't use them for the initial chocking. I use some wedge chocks first on both sides, and once the TT is immobilized, I then slap the X-chocks on. Plus, with two long-shackle padlocks, the X-chocks function as a decent theft-deterrent, although the padlocks will fall in seconds to a set of bolt cutters.
  • I had one of each. The deluxe was heavier. But they both seemed to work very well on my 20ft TT.
    When I went to a 40ft 5th with 6pt level up, they did not do much.
  • I've had both. Deluxe have a bigger footprint but don't close as small as the X-chocks. I don't really notice much difference in performance. Either will work fine if they fit between your tires.
    FWIW...Roto Chocks are the ultimate....
Having RV issues? Connect with others who have been in your shoes.24,211 PostsLatest Activity: Mar 08, 2025
