HadEnough
Jan 24, 2021Explorer
time2roll wrote:
Brownout as in low voltage? You will need to take some measurements with your voltmeter along the pathway.
Possibly just tighten all connections including at least the transfer switch and the breaker panel.
May want to start at the source when measuring voltage.
I’d love to. But you can never know when the problem will happen. It happens after like 5 hours of good power sometimes.
The air conditioner slows down. So I stop it immediately because I don’t want to damage it from bad power. I rush to check the power and it’s better already. Then it dies again. It’s completely intermittent.
Definitely starting by checking connections
