3_tons
Jan 25, 2021Explorer III
enblethen wrote:
If your transfer switch is readily accessible, you might try connecting your shore power cord wires directly to the wires going to the distribution panel using wire nuts. The using portable genset see what happens.
By doing this to take the transfer switch out of the equation.
By passing was suggested by others,
X2
“Unfortunately, I’m guessing I’m down to eliminating components at this point.”
Since it happens with either genny I would doubt it’s the shore power cord. Do not dismiss connections at the main panel and the possibility of a defective main breaker...
3 tons
