C_Schomer's avatar
C_Schomer
Basics of Lithium conversion... I'm lost!
I did a search and it's mostly Greek... to me. I'd like to know the key points for, hopefully, a straight across lead/acid to lithium conversion.
My old Flow-Rite watering system just overflowed 2 cells (GRRRR) and I'm thinking this might be the time to convert.
So far I see that SiO2 is better than Li but I don't know why or what the difference is, and charging is much simpler for lithium and not so fussy.
I currently have 2 of the bigger Sams 6gc's that have dimensions and specs similar to T-105s, 2 X 120 watt panels and a Morning Star controller with remote panel/setpoint, that the PO installed.
I don't use an inverter for any 120ac loads. I'm nearly always plugged in to 120. I have no big 12vdc loads... my 5er has full LED lighting but I use a 12vdc bipap for very rare boondocking. The biggest addition might be a 12vdc fridge, someday.
Is there 6v and 12v lithium batteries? I seldom need the capacity I have now but I don't want to give it up, for the times I need the 12vdc bipap. Can I get similar capacity with lithiums and also fit the 2 x 6gc foot print? How much capacity to run a 12vdc fridge? Do I need a different solar controller or just reprogram my existing one? Thanks bunches! Craig
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 24, 2025
