tvfrfireman
Nov 04, 2013Explorer
I charged all four batteries and then disconnected them and let them sit for a few days. They all read the same volts. The two I mentioned that read differently were hooked up to the leveling system while the other two in another compartment were disconnected. The only wire I can find upstream of the battery shutoff switch is two the leveling system. Would those post mounted shutoffs suffice in this situation or should I go with the more expensive wall mounted switches?
