DryCamper11
Nov 04, 2013Explorer
tvfrfireman wrote:
I charged all four batteries and then disconnected them and let them sit for a few days. They all read the same volts. The two I mentioned that read differently were hooked up to the leveling system while the other two in another compartment were disconnected. The only wire I can find upstream of the battery shutoff switch is two the leveling system. Would those post mounted shutoffs suffice in this situation or should I go with the more expensive wall mounted switches?
This indicates that the batteries are not self-discharging beyond normal rates. Since you are seeing much faster discharging when connected, even with your "disconnect" actuated, you've got a current drain. If you are correct that the only wire that the "disconnect" doesn't shut off goes to the leveling system, that should be your problem. Personally, I'd check it by measuring the current drain with a meter. Once you have identified it as your problem, you get to choose a solution.
I think everyone here will agree that the "the more expensive wall mounted switches" are better. You can buy good quality units that will last a long time and not fail when you need them. It's probably what I'd buy if I bought a disconnect switch. I like quality.
OTOH, I don't have the room for mounting one, don't really like running more cables around, don't want to incur the expense, and don't like the cheap post mounted switches. So, I get by with just removing the battery cables when I need the battery disconnected. Sometimes simple is good.
You may consider putting a second switch in the wire that's draining your battery. Then you'd need to throw two switches to "disconnect". Or you can move that wire to the other side of your existing switch.
