Slownsy's avatar
Slownsy
Battery boxes
I designed my new battery box for under the FW to take 4- 6V 260A Crowns, They are lined op side to side, I have 1/2" end play at side and about 1/4" at ends, I have read to allow 1" gab betvin but seen plenty bundled together like mine in difrent configurations is this ok or not, I do have temp gage on them and think the space is for cooling and expansion when charging. I do have a couple of holes near bottom of box and also a tube attached at top to outside for gassing. Any thoughts thanks.
Frank.
  • I chose the Crowns as I had read wery good things about them, the plates a lot thicker and hewier than most and the 260A rating compared to most chipper 100A bought them out of Lakeland FL and they transported to Fort Myers wher I met up with driver, wery good to work with, Fisher batterys I belive.
    Frank.
  • I just bought and installed a new battery box for four 6V batteries and it has about the same space between the batteries. I'm sure you will be fine with your set up.
  • I thing you are fine. Can't imagine that much expansion but maybe a little. I'm curious why you chose Crown? We might need some and I've heard good things about them and Lifeline.
Having RV issues? Connect with others who have been in your shoes.24,400 PostsLatest Activity: Jul 22, 2026
