Oasisbob
Feb 18, 2014Explorer
BATTERY CHARGER MYSTER & ?
This morning I decided to perform a maintenance charge on my twin group 27 deep cycle batteries which are isolated from everything via cut off switch. I first hooked up red (positive) charger clip to positive battery terminal then as I began to hook up negative charger cclip to negative battery terminal I noticed an arc. Very odd I thought as I had not yet plugged in charger. So I took off positive and put on negative first. I, again, noticed an arc when I put on positive clip last. The charger is a Chicago Electronics (Harbor Freight) unit which does 6 or 12 volt batteries with amp selections of 2, 10 and 55 for jump starting cars. I had set charger for 2 amp charge. The second I plugged in charger my cord leading to battery clips began to desinigrate before my eyes. Went up in smoke. I,within 5 seconds pulled AC power cord out of the wall then removed battery clips. All insulation on negative cable was gone burning my hand. I put a volt meter on battery and got 12.45. While ripping off battery cables I noted correct polarity. I am baffled as to what happened. There is a reverse polarity indicator on charger which never lit. Any thoughts on what went wrong here? It really concerns me There is no model number on this unit only mfg, date of 2/05 and serial # plate.
