PaulJ2
Jan 14, 2019Explorer
Battery chargers.
Maybe a question for Mex.
Stone dead 12 volt battery on my Prius. Gone for a week and door ajar causing dome light to drain battery.
Brought out 2 different battery chargers,neither one would put out any voltage. One an automatic 10 amp unit and the other 1.5 amp battery charger/maintainer unit.
Measured voltage at the dead battery was .3 volts.
I then drug out my 30+ year old 1 amp motorcycle manual charger. Worked fine! Is this some safety thing so you can't spark the two clamps together?
I guess they have to see a couple volts before they will operate.
Geeeez!
Geeeez!
