joesmail84
Apr 27, 2023Explorer
So it was not the switch. Either switch works to turn off the solenoid but blow the fuse turning it on. I tried a 5 amp fuse and it failed as well. I think I have a short in the wiring from the switch to solenoid or the solenoid is bad and requires to much draw to turn it on. hence, blowing the fuse.
Having RV issues? Connect with others who have been in your shoes.24,209 PostsLatest Activity: Feb 26, 2025
