amxpress
Jun 10, 2018Explorer
You might consider performing a parasitic draw test on the system using your multi meter. All items turned off, connect your ammeter in series between the Negative post and the Negative battery terminal. I don’t know what an acceptable draw is on your rig, perhaps someone with a similar set up can tell you. It is difficult to use an Ohmeter to test your system, but you can perform Voltage drop tests to check for poor connectors, corrosion, etc. But that’s another “how to”story.
