tommymsw
Apr 11, 2017Explorer
Battery/ inverter question?
So I am new to this. New to me, OLD RV. I've just been fixing it up and I am almost finished.
I bought a little "cigarette lighter" inverter. It works fine in my car. But when I put it in the RV (plugged into the lighter outlet in back) the light is orange (Indicating over or under amps).
I do NOT have a battery in the RV right now. My question is, do you think that the inverter is doing this because the converter is bad? (It shows almost 13amps when I test it, but my car shows almost 16). OR... Do you think this will all go away when I add the battery? Like the converter will charge the battery and the battery will give the proper amps to make the inverter work? Or is that stupid?
Maybe when I am hooked up to shore it does not even go through the battery?
