Have 4, 6 volts batteries . Can I use 2 battery maintainers one for 2 6 volters , the other hook to the other 6 volt pair. Will that be good for alright to do?
You have 4 , 6 volt batteries set up to operate as 2, 12 v batteries. Use one maintainer with the positive hooked to positive pair A and the negative to negative pair B. I ran mine in this manner off of a BT Jr which is a .75 A maintainer. Come in off the road, turn off the manual disconnect and plug in the maintainer. The maintainer will usually be in maintenance mode by the following morning. Randy Bergen
