schlep1967
Jul 10, 2017Nomad
I am anti-impact for stabilizers.
I am a fan of Home-Depots Rigid tool line. You can get a good 18 Volt drill driver there and the best warrantee you will find. Lifetime on the drill and the batteries.
I could understand having a separate impact driver for removing lugs but I would caution against over torqueing them on install. Any mechanic worth anything will run the lugs on and then use a torque wrench to finish.
