- HuntindogExplorer
rbpru wrote:
I have two EU2000s. I also have an 600 watt pure sine wave inverter and an automatic transfer switch with two 6 volt batteries. The inverter powers all 120 volt circuits except for the converter.
After spending four day nursing a 12 volt battery to just run pump, led lights and the phantom loads like the frig, propane detector etc. I cannot begin to imagine the battery bank needed to run coffee pot, microwave, and fans; let alone the air conditioner through an inverter.
If you want 120 volt power, it sound like a job for a generator.
It is VERY nice to have 120 at all times. The clock on the microwave always works, as well as all three TVs, sattelite box, laptops and phone chargers, electric shaver etc.. Naturally I know not to fire up the microwave or AC, without running a generator... But this is the best setup I have had as far as ease of use and being able to run everything, with reasonable economy.
I highly recommend it. - rbpruExplorer IIAfter spending four day nursing a 12 volt battery to just run pump, led lights and the phantom loads like the frig, propane detector etc. I cannot begin to imagine the battery bank needed to run coffee pot, microwave, and fans; let alone the air conditioner through an inverter.
If you want 120 volt power, it sound like a job for a generator. - Sam_SpadeExplorer
wing_zealot wrote:
Most people don't camp unless they are plugged in. Most people that camp while not plugged in don't plan on using the power outlets, microwave, A/C, etc. (120V power).
Really ??
My experience tells me that NEITHER of those statements is true.
Nowhere near to "most". - dewey02Explorer II
jesseannie wrote:
We were camped at Marble Canyon on the Colorado River one late spring day and a couple pulled in in a nice used tent trailer. It was obviously their maiden voyage. After they set up he was crawling around under and inside the trailer.
It was a HOT day approaching 100 and no hook1ups at the Campground.
I went over to visit and he told there was something wrong with the electrical because when he plugged in his two household fans they did not work.
I explained the facts of 12 volt life to him and he was visibly shaken.
Soon after, we heard some loud discussion between the couple as they were breaking camp.
She was in the air conditioned car while he got everything else ready.
Short uncomfortable introduction to camping.
Jesseannie
Funny story.
Live and Learn...and remember to keep mama happy, because...well, we all know the rest! :)
I've installed 12 volt outlets in 3 places (bedside, kitchen counter, and over the dinette) to run our 02Cool fans. D.E.Bishop wrote:
I think the fridge is standard propane/120v with 12v controls.
Roy, I am not trying to argue with you but why did you choose a diagram that shows 120vac running to a 12vdc/propane refrigerator? Also why not have the ATS instead of an optional surge protector. Most times you see the SP on just the shore line.
Yes the transfer switch seems missing. Although a lot of MHs plug into the generator direct with the utility cord.- D_E_BishopExplorerRoy, I am not trying to argue with you but why did you choose a diagram that shows 120vac running to a 12vdc/propane refrigerator? Also why not have the ATS instead of an optional surge protector. Most times you see the SP on just the shore line.
- wing_zealotExplorerMost people don't camp unless they are plugged in. Most people that camp while not plugged in don't plan on using the power outlets, microwave, A/C, etc. (120V power). If you plan on camping without being plugged in and still have 120V power plan on spending a few bills with Grover Cleveland's picture on them.
- jesseannieExplorerWe were camped at Marble Canyon on the Colorado River one late spring day and a couple pulled in in a nice used tent trailer. It was obviously their maiden voyage. After they set up he was crawling around under and inside the trailer.
Jesseannie - RoyBExplorer IIIThis is a typical 30A RV Power Distribution Block Diagram. Please note how everything is connected either to the 120VAC Distribution Panel or the 12VDC Power Distribution Panel. This is the 'HEART' of your RV unit...
Google Image
This shows how the 120VAC and 12VDC Electrical Power is made available for your on-board appliances, power outlets, and systems... The RV Concept is to run your installed appliances and systems when you are on Shore Power or Generator or just running the few required items when just running off the battery. The typical battery is small in size and is not a large enough source to run all of your installed appliance so only just the necessary items are made available to you..
As stated above if you want more items to run in your trailer when off-grid somewhere you will need to run a larger generator or add more batteries to run a large POWER INVERTER...
My current battery which is now almost consumed and needs replacements has been at 255AH Capacity since around 2009 and this small inscrease only allows us to run our Home entertainment items and just a few additional small wattage 120VAC items. We get to light up our off-grid area outside and have just a few additional low wattage items we like to have along with us and then around 8AM the next morning we run out 2KW Generator with the trailer shore power cable plugged into it to run the on-board converter/charger unit to recharge our 50% depleted 255Ah Battery bank backup to its 90% charge state so we can do all of this all over again for the next day/night off the batteries. This takes three hours of generator run times for us each morning. Of course some places do not allow the use of the portable generator so when this happen I have to remove my batteries and take them down the road somewhere where I can run my portable generator on the side of the road somewhere using my portable 40AMP smart mode charger. This takes more than three hours of run time to recharge my batteries... The rule of thumb is to have at least 17A to 20A of available 12VDC Smart Mode Charging Power for each battery you are having to charge.
Been doing this routine since 2009 and it is second nature now for using my OFF-ROAD trailer off-grid without shore power.
Roy Ken - Sam_SpadeExplorer
4aSong wrote:
Another alternative would be to carry a portable generator.
Which is a much better alternative for most people since it gives you more flexibility to run high current devices......like microwave and A/C.
