MarkTwainExplorerNov 04, 2020Battery switchShould the battery switch be left on while your are RVing and only turned off when you put your trailer into storage???
way2rollNavigator IINov 08, 2020pianotuna wrote:Steve,Usually solar is direct connected to the battery bank.Mine also. I use the disconnect switch in storage and my solar still charges the batts.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,211 PostsLatest Activity: Mar 11, 2025
Related ContentHouse battery switchBattery disconnect switchBattery Disconnect SwitchBattery Disconnect SwitchBattery cut off switch
