wa8yxm
Sep 01, 2019Explorer III
There are 3 ways to attach the temp sensor. One will require an additional part
IF the sensor has a "lug" attach to the NEgative battery post (You can also use positive but for some reason they say neg in the destructions)
Double faced tape
Put a cargo strap around the batteries to keep them tight together and drop it in between them like you did in the old days. (What I recommend)
Double faced tape
