kcgaz's avatar
kcgaz
GM 8.1 Workhorse O2 Sensors
We purchased a 2003 Holiday Rambler with a GM 8.1 Workhorse Engine. It appears to be in great shape visually, only has 20K miles on the engine, but when driving it on the freeway the other day the check engine light came on and I lost power. Luckily I was able to limp to the off ramp and into a shopping center. I had it towed to the Chevy Dealership and they have now had it for several days. I received a call that they tested it and code 202 came up which is for the O2 sensors. They said they cleared the codes and test drove it and all is fine so far. They said that they want to put more miles on it to see if they can get it to trip the code again so that they can determine what is causing the problem. I am concerned that the issue has really not been solved with clearing the codes and that it may reappear at some later date. Should I have them replace the O2 Sensors even if they can't get it to trip the code with test driving? Any insights, advice and past experience is always greatly appreciated and Happy Holidays!
