drsteve
Dec 17, 2019Explorer
MDKMDK wrote:Son of Norway wrote:
I buy pure (no ethanol) gasoline that I keep on hand in a couple of 5-gallon cans for snow blowers, lawn mowers, power washers, portable generators etc. The STABIL products that I buy indicate their use for alcohol-blended fuels. Are there any fuel preservatives specifically for pure gasoline and which one would you recommend? Thanks for your help.
Agree with Old Wizard - unless you go through a 5 gallon can once every decade, I probably wouldn't worry about it going bad. Even stored for that length of time it will probably still work.
Honestly, I tried fuel stabilizer about 10 years ago, and there was no noticeable difference in the fuel quality that I put it in, versus the last 10 years of not bothering. I've left ethanol laced, and pure dino, gas in my shed over the winter and it still works, when I use it next year in the mower/tractor.
Some believe that some engines might prefer you use it all up, to dry, before long term storage. However, I've never done that either, and had no problems.
Same here. I use 10% ethanol regular pump gas and no stabilizers, and I never have an issue. Been doing it this way for many years.
Every piece of power equipment produced in the last 10-15 years is ethanol ready.
When it comes to lawn mowers, string trimmers, power washers, etc. there is no advantage to premium fuel, non ethanol gas, or stabilizers, in my experience.
