Bobbo
Dec 18, 2019Explorer II
drsteve wrote:
Same here. I use 10% ethanol regular pump gas and no stabilizers, and I never have an issue. Been doing it this way for many years.
Every piece of power equipment produced in the last 10-15 years is ethanol ready.
When it comes to lawn mowers, string trimmers, power washers, etc. there is no advantage to premium fuel, non ethanol gas, or stabilizers, in my experience.
You have been lucky. I was lucky for many years, until I wasn't. Finally, over a period of 2 or 3 years my lawn equipment got to running worse and worse. It even got to where I had to use ether (starter fluid) sprayed into the carburetor to start some of them. Then I discovered Seafoam. After using Seafoam at double the recommended concentration for one season, my engine troubles were gone. I started using Seafoam in every drop of lawn equipment gasoline. It was sometime after that I started using ethanol free gasoline in my lawn equipment.
I hope your luck holds.
