ScottG
Feb 05, 2019Nomad
joebedford wrote:ScottG wrote:How did you get the screws out?
I put a jack under the s/o and lifted it about 1/4", just enough to take the load off the rollers individually
I'm sorry, I mixed up my two different kinds of slides. The noisy rubber rollers (or wheels) were on the rack and pinion slide and not in the floor like I intimated.
You can see the rollers in this pic and I'm pointing to the nut on the end of the bolt.
Once the weight is off the rollers, it's easy to remove the bolt and roller to lube them up.
I hope this helps someone!
Having RV issues? Connect with others who have been in your shoes.24,192 PostsLatest Activity: Jan 26, 2025
