mrad's avatar
mrad
Nov 04, 2018
best practices for long battery life
I cannot get more than 3 years out of my battery on my TT. Original battery was an interstate. It was replaced under warranty going into its third year. The replacement lasted two years. I then tried the walmart brand. This was it's third year. When putting it away for winter storage this year, it would not raise the tongue jack when not hooked up to shore power. When I checked the battery indicator in the TT, it showed it had no power 15 minutes after being disconnected from shore power.
I leave the TT plugged in all year once we start using it. Usually May- October. After that it goes in my basement and gets a charge every 2-4 week until ice fishing season. Then I take it to the fish house every weekend (Mid December through the end of February). I use it with a 750 watt inverter to run the tv and lights/ ceiling fan when I tune the generator off. I can usually get 6-7 hours on the battery before it needs to be charged. I then start the generator and charge it with my vector smart charger until it is full.
Should I be turning the disconnect switch off in the summer when it is plugged in at home, or is 2-3 years the average life span for a deep cycle battery?
Having RV issues? Connect with others who have been in your shoes.24,351 PostsLatest Activity: Jan 21, 2026
