BFL13
Nov 05, 2018Explorer II
Cydog15 wrote:pianotuna wrote:
For some reason it appears that during winter the battery is being either deep cycled (below 50%) and/or chronically under charged.
Trojan wants 14.8 volts to fully charge their 12 volt products.
That is true and Probably why I would use the special version of the PD 9200 series designed specifically for it. That or the Boondocker you can adjust.
Since that 14.8v is only right for 80F, and the concern is for MN winters, where 14.8 is now 15.2 or so, why bother with a fixed 14.8?
You need 14.8 temp compensated, or adjust the voltage yourself to suit the temperature. That makes the Boondocker adjustable (a version of the PowerMax LK models) the better choice.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
