โJul-28-2021 07:25 AM
โAug-26-2021 12:49 PM
โJul-30-2021 06:50 PM
โJul-30-2021 08:10 AM
FWC wrote:Problem solved. As I posted install it in a vented box near the battery. 100V input voltage means you could have a 3rd panel later if desired. Need to check on the 290W spec. My controller is OK with overpaneling.
The Victron MPPT 100/20 is the 'best' MPPT Charge controller for your application. It IP43 rated, so fine for spray and splashes, but I would still put it in some kind of enclosure. Maybe a small Pelican box so you can easily open the lid for ventilation when it is working hard.
โJul-30-2021 07:52 AM
โJul-30-2021 07:36 AM
โJul-30-2021 07:08 AM
โJul-30-2021 06:53 AM
2oldman wrote:Bobbo wrote:Thanks. That would have been good to know up front.
No. My battery box sits on the tongue and has no space inside. My TT has no way for me to put the controller for a suitcase panel inside.
Bobbo wrote:
However, I still need a weatherproof MPPT controller.
โJul-30-2021 06:23 AM
โJul-29-2021 09:05 PM
โJul-29-2021 08:59 PM
โJul-29-2021 07:14 PM
2oldman wrote:Bobbo wrote:This still isn't making any sense to me. If the controller is close to batteries, wouldn't it be inside?
Reason for weatherproof: set up suitcase panels with controller not in enclosed space and go sightseeing. It rains. Rain can happen when not expected.... put the solar controller close to the batteries rather than at the panels.
โJul-29-2021 07:37 AM
Bobbo wrote:And series panels with bypass diodes and a MPPT have better shade tolearance than than parallel panels. 12V panels may/may not have bypass diodes and 24V panels certainly will have bypass diodes. Disclaimer: This topic is often not understood.CA Traveler wrote:
My 3 series panels on the roof have 62' total of 10 gauge wire to the controller resulting in 0.4% voltage drop which is very low. ie The panels on the ground could be about 31' from the controller.
You say your panels are SERIES. That is exactly what I am trying to accomplish. The weatherproof PWM controller that Renogy sells can not handle the panels in series, only in parallel. That is why I am wanting an MPPT controller.
โJul-29-2021 07:32 AM
โJul-29-2021 06:47 AM
