CR_CRUISER
Apr 14, 2017Explorer
Black Tank Handle pulled out of valve
Last fall before I put the fiver to bed for the winter, I replaced both the grey and black tank valves as they were leaking slightly. I lubricated the slides with silicone grease and they slid back and forth quite easily.
We used the trailer last weekend and when I went to dump the tanks, the rod on the black tank valve pulled out of the slide. I didn't reef on the handle, just pulled it as I normally would. No amount of playing with it would get the valve to open.
Now what do I do? There's about 10 gallons of ickys in the tank and short of unbolting the valve and having pour out on the ground, how do I empty the tank so that I can replace the valve again?
