richy2's avatar
richy2
Aug 19, 2013
Black Tank incident
In the process of flushing my black tank I close the valve add water and dump and repeat several times. During one of the cycles I became distracted, forgot about opening the valve and heard three loud pops, went around to open the valve and noticed clear water dripping from the tank area. I could not see exactly where it was coming from because it's enclosed. I assumed something was broken, however, the dripping stopped after a while, I have since used and flushed the tank as usual a few times without any issues, every thing seems ok. I am not going to fix anything that is not broken but I am curious about the pops and dripping. Any ideas?
Thanks
  • You should open underbelly and find the problem now......otherwise you will be finding it latter when the tank is full of poop.
    Tank strap/support broken
    Vent line/drain line from toilet pushed out of grommet
    Tank seam cracked
    Insulation soaked
    Flush line cracked
    Above are just some of the possibles for that loud pop and dripping water.
    Nothing inanimate fixes it self....but it can/does get worse
  • There is a vent for the black tank so you can't raise the pressure to the city water pressure but you can build it to the 12' or so head pressure to the roof where the vent is. The large area of the black tank walls might make the tank expand enough to pop a support strap. I would be worth a look.
  • My guess is there is a hole somewhere on the black tank. Maybe it is high enough that it wont create problems though. I did the same thing with my last trailer. Lucky for me, the tank is exposed underneath. In my case I went into the house and forgot I was filling it. I heard a loud bang and found a steel strap had broke off that supports the tank. The tank expanded enough to blow that off. I also had some water come through the floor inside around the toilet base. It never caused any problems though after that.
Having RV issues? Connect with others who have been in your shoes.24,347 PostsLatest Activity: Jan 10, 2026
