Old-Biscuit
Jul 07, 2019Explorer III
Typically waste tanks are sloped...shallow end under inlet pipe.
Whenever using TP you should FILL the toilet bowl FULL prior to flushing so you have good volume to carry stuff away from inlet area
Just the nature of gravity toilets.
Shorter the drop the more likelihood stuff will collect if NOT using enough water when flushing
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 04, 2025
