Old-Biscuit
Oct 11, 2015Explorer III
Topic: Black water toilet plugged
Posted By: Happycamper30 on 10/10/15 09:42am
Does anyone know how to unplug a toilet we use Rv'ers tissue.
Happycamper30 wrote:
Mine seems to be by the black water valve I pull on the valve handle the valve shows it to be open because the rod moves under neath the belly but my question s since the holding tank is full how do I manually pull the flapper valve back without a mess
Thank you
So your toilet isn't plugged ?
It's the tank drain valve not opening?
Tank drain valve........you need to access the valve. If you have an enclosed underbelly that means cutting a 3 sided window (access panel) so that you can use a pliers on valve shaft and pull it open then you can repair valve if possible or replace as needed.
Having RV issues? Connect with others who have been in your shoes.24,187 PostsLatest Activity: Jan 14, 2025
