MEXICOWANDERER's avatar
Nov 30, 2015
Blinking 12 volt LED With 120 vac Power Supply?
I have lots of items I wish to monitor via eyesight at night. Like power to a pump 200' distant with bare rock in between. Power to the gen shed with 300' in between me and the devices. Yeah I could do it with relays, voltage buckers, etc. etc. But some of these things are outside and I don't feel like spending a fortune on larger project boxes and wiring stuff up.
I can see a 3.2 volt 20 ma blinking green LED at night even at 300' The BREAKERS are a 70' walk sometimes through driving rain to a NEMA 4 enclosure. The gen shed has it's own service service drop.
A power outage monitor is easy to configure for inside. But not so easy for the outside stuff. And I have indeed lost service multiple times to several critical outside devices. And not known it.
That's the justification for the work...
I would like to use plastic handy boxes, sealed up, with nylon blank plates drilled for a 5 mm LED holder.
Also inside the box would be a 7K 5-watt ceramic resistor. I have a bunch of everything listed here and a chance to order whatever and get it down here next month. I do not want to spend a King's Ransom on this.
Is there any problem with the ceramic resistor / enclosed 12 volt blinking LED combination?
Call it a wireless power outage indicator.
