s_N_s
Nov 01, 2013Explorer
Brake light issues
I'll try to keep this as simple as possible. At the rear of the coach I have the 7 pin receptacle. I plug in my 7(which is actually 6 pin as the center is blank) pin to 4 pin adapter and it has right and left turn signal and marker lights but does not activate the brake lights thru the adapter. ???? Am I missing something here? I've always thought that the turn signal pins are the same for the brake lights. The brake lights on the back of the coach work. I should mention, I do use magnetic lights on the toad but don't see that should effect anything.
Hope this isn't to confusing.
