hypoxia's avatar
hypoxia
Carefree Awning Current Adjustment
The awning controller has an adjustment labelled "Current Adjust". Is there a published procedure to adjust the awning controller current? This is a One Touch awning but they are probably all the same.
  • hypoxia wrote:
    dougrainer wrote:
    WHY do you need to do that? Doug
    The awning is sluggish & moves very slowly. If there's a 15 knot breeze it needs help, someone pushing on the arms. I wash the straps and am liberal with silicone on the straps which helps quite a bit but doesn't cure it. It is a 13 year old One Touch patio awning.
    One Touch Awning
    The current adjustment is for the In and OUT stops. From your complaint, your motor is bad. The current adjustment does not fix this type problem. Doug
    One Touch Awning
  • If this isn't sufficiently covered in your Carefree owner's manual I'd call the company and ask them.
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 02, 2025
