- teddyuExplorer
Old-Biscuit wrote:
It indicates you have power to control board.....no red light...no power.
X2 If light is out (no 12 VDC) and 120VAC is present the unit will not run. JM2¢... - Golden_HVACExplorerHi,
Some boards just blink. When there is a problem, then the blinking might be one long blink followed by several short blinks. Or two long and 1-6 short. Something like that will be de-coded in the repair manual.
Some might be as easy as blocked drain line, or high pressure, or something like that. You can prevent high pressure from tripping by washing the outdoor coil with a garden hose once a year or so.
Fred. - newman_fulltimeExplorer IIyou need to reset your thermostat it has lost communication to it
- Old-BiscuitExplorer IIIIt indicates you have power to control board.....no red light...no power.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 18, 2026
