Mako_Kupo
Sep 29, 2017Explorer
Caulking & Spray Foam
he everyone! two questions here, fully rebuilding a '79 Ford Class C (Coachmen). anyway;
there is an absolutely ridiculous amount of caulking on both sides of every metal outside panel. I have managed to get the gray, almond, and most of the white caulking off with mineral spirits, paint thinner, and general caulk remover from Home Depot unknown brand. there are two types of caulking on here that nothing touches, one of them is silicone and the other seems to be some kind of rubber or glue. the roof especially, it seems to have been glued down(not caulked) to the wooden part of the roof.
how do I get rid of these? I do not care about the paint, for the most part. to remove the silicone, iu have already stripped a ton of paint off right down to the metal, and I've only just begun not he silicone. oftentimes I get through the pain before the silicone STARTS to come off.
so, I'm going to get a Dremel with a wire brush scrubber on the end. for the silicone, I've been using my Oscillating multitool and for the tough stuff, a power drill with wire brush. a Dremel would work MUCH better for this, since the wire brush keeps sliding out of the drill and are actually designed for the Dremel rotary tool. will this work for that? the rubber stuff refuses to come off with anything less than the power drill + wire brush + pushing down really hard + 10 seconds per inch, if not more. I am hoping it will work for both of these types of caulking(praying, and I am not religious).
second, I am doing spray foam myself. I do not know which brand to get, if any of them stand out as the best I will go for it. I need about 600 ft, which luckily is what the good size ones are rated for. I want to swing for a little bit more, so I can do two coats in spots that allows it. thank you everyone!
