MrWizard
Jan 20, 2018Moderator
1L243 wrote:
what kind of inverters are you using that would be so expensive. Just doing a quick search I cam up with this one.
https://www.amazon.com/gp/product/B0015353XU/ref=as_li_ss_tl?ie=UTF8&camp=1789&creative=390957&creativeASIN=B0015353XU&linkCode=as2&tag=gonwitthewyn-20
I was thinking that you actually replaced the converter charger and replaced it with the inverter charger? You supposed to run both?
My dream system would be 6 batteries with solar.
Ok it's five time as much instead of ten
Go power is ok brand, i have their 300w
But that is an inverter only
No charging
that is useless for what you want to do
Those plugs on the front, are not going to allow you full power use for the whole RV
You need an inverter that is hard wired, not plug in outlet's
If you expect to put it in line, for the whole RV
