jimdmorrison
Jun 16, 2020Explorer
Changing oil & can only fit in half a quart :S - QG 4000
I just put an Onan QG 4000 in my RV. It was used and the fuel float was stuck, but I think we got that taken care of. Since fuel had gotten in oil, I tried to change the oil today. Seemed to all flow out easily since it had gas in it.
I went to add oil and after half a quart, it overflowed. Doesn't seem to be settling down in there. (capacity is 1.6 quarts)
Tomorrow I will drain again to see if that half quart comes out.
Any suggestions? Do you normally have to add a little at a time? I'm hoping I don't need to drop oil pan.
Concerning side note: Before I changed the oil, running the generator built up oil pressure, causing it to spray out the next time I opened the dipstick.
