joraz's avatar
joraz
Charger not Charging
Heart Interface Freedom 20 Inverter-Charger
This is original equipment on a 97 class A. A month or so ago I noticed that the batteries were not being charged. I checked the breaker and reset the breakers on the charger, neither of which appeared to be thrown. Anyhow, I unplugged and plugged in a couple of times and the charger came on. All has been well (parked and plugged into a 30a box) until today. I noticed that the charger wasn't working. Everything else is fine (all outlets, microwave, etc.).
Now for a bit of weirdness. I unplugged and tried the inverter with the microwave. I watched the amp draw from the batteries on my Trimetric. It moved up to 80, 90, 100, 125 (that's where it would normally stop) and just kept going. I didn't get it shut down until it had reached around 200 amps! Then the autostart on the generator engaged and tried to start. Anyhow, everything still worked fine and the inverter-charger was not hot on its exterior. I tried the inverter again (with my finger on the microwave stop button) and it operated normally.
So... the charger has quit but everything else works when plugged in, when unplugged and when on the inverter. Do I need a new inverter-charger? Thanks.
Just thought of another info item. The panel for the Freedom 20 was blinking an error code. The book says that indicates Thermal Shutdown and recommends cooling and cycling power switch. The error is not showing now; it indicates charging but is not.
jor
