jwilson32
Jun 29, 2015Explorer
Chassis Disconnect Issue - Why?!?!?!
So we've been really enjoying our 02' Coachmen CC Elite MBS354 for the past few months. The kiddos have loved it and it sure beats tenting it! haha... My question is from an issue with the chassis disconnect that occurred last night when leaving the campground....
We set up camp around 8pm last Friday and broke camp last night around 7pm (3 day trip). We were connected to 50amp shore power the entire time. When I went to start the motor, it was dead. I tried using the button that uses power from the house batteries, but there wasn't enough there to turn the motor over. I looked at the chassis disconnect light which was really dim. I pushed the disconnect button a couple of times and it would shut off and turned back on, but still dim. Tried jumping with just one set of cables and no dice. Luckily my buddy had a diesel pickup with two batteries. We connected a second pair of jumper cables and she fired up. The problem is, the chassis disconnect light isn't on at all and I don't have any power to Wipers, Mirrors, Chair, AC or defrost fans. Everything else works such as gauges, shifter pad, lights, dash lights, etc. I checked all of the house breakers and fuses, all of the fuses located near the chassis batteries and the relay fuses as well. All were good. I also pulled the disconnect panel and found one glass fuse which was good.
I also want to mention that the system is charging as well. We pulled in last night around 2am and when I went to move it this morning, it fired right up. My wife had an electric cooler plugged into the 12v cigarette outlet on the dash. Could that have drained the batteries? If so, do they not charge when connected to shore power?
I cannot figure out where else to look or where to start? Any suggestions would be greatly appreciated. I'm not an electrician by any means, but can use a volt meter and would much rather spend my time looking for the issue than paying the dealer. Of course if that's the last resort, I guess it is what it is.
But I bet with y'alls help I can do it!
Please LMK if you need any other info...
